Pros and cons of putting springs back on the hood hinges with this old fiberglass hood:
Pros: no mor prop rod, the curve in the reveal is pulled down even with the fender
Cons: I can’t close the hood without getting on the step I use to work on the engine.
Take away, anyone ever heard of lighter springs available???
I got some springs from my local hardware store. I think I have a couple more that I can get the part # from. They hold the hood up as long as there's no breeze from the rear.
What kind of weight difference is there between stock and this one?
Does your fiberglass have any internal reinforcements?
I’d say the hood is at least half the weight. Now it is a beat up old hood that I suspect is reinforced but already somewhat damaged from previous use with springs and that s why the reveal is curved
So typical for me, I forgot to take a finished pic but I removed the factory ac blower box. This one I found locally for half what they charge. Firmest was pretty good. I had to bend the legs of the resistor and modify it to fit. Also used an old beer coozy for a gasket bc the surface wasn’t super flat where I installed. Info to order is in the pics if you want one.
Reinstalled the steering column after installing new lower bearing and plastic housing. The cap and clip are new as well. Also cleaned the shaft with emry and tightened up the ignition switch. This started in hopes to find why there’s a power draw. I’m not sure if this is a fix yet. I didn’t see much evidence that this is where the problem was but things should be much smoother as the old parts wet rusted out completely.
New vents and Silverado dash trim as well. Already broke one of the posts of of the trim:surepal:
Oh that would be great if you still have the part number
I'll see if I can dig them up shortly.
When I got my truck, the stock springs were employed and they were bowing the hood. I removed them and ran spring-less for about 10 years. Then a couple years ago I installed the lightweight springs. I recently realized that the hood is not bowed anymore. It happened slowly over time, I don't know if it was a 2 year fix or a 10 year fix, lol.
Love that truck
Hey fam! Had emergency surgery on my spine 8 weeks ago but I’m back at it. Financially ruined but I’m high spirits!
Anyhow, my dually has been in the barn leaking trans fluid from the dip stick grommet since. The shots with the pallet of concrete.
The starter that’s smaller bc it’s for an LS was not mating with the flex plate enough and eventually wouldn’t turn over and sounded blood curdling.
In the past I ordered a billet mini gear reduction starter from jegs (I don’t deal with them any longer) and it didn’t engage with the fed plate at all. I can’t use a factory starter bc the body interferes with the dip stick of the moroso pan. I have plenty of factory big body starters.
Truck on the lift I decided to dig in. Sent the bendix out and the gears weren’t even close. Disassemble clamp on the ol mill and fly cut 100 thousandths off and clearances for the pan flange. Bam! Perfection! Not bad for a hand job!!!!
