Had a good work day in the Bigassgas garage over at Larry's place. Went over with the intention to troubleshoot/fix the rear brakes. Then if we had time we'd look at mounting the winch bumper Larry squirreled away some time ago. As odd as our luck is, the brakes turned out to be ok. The prop valve seems to be letting fluid back as we've got solid rear brakes. We did pressure bleed it just to make sure and it all came out ok.
So we moved on to the winch bumper. We had free time in the shop from both our wives so we needed to make use of it. Out of Larry's storage yard came a bumper that he picked up many moons ago. We drug it inside and mocked it up.
We used the finicky bumper jack (fitting right?) to hold the unit in place. Surprisingly for us the inside of the winch box matched up perfectly to the K5's frame rails for width. Despite the Warn sticker, to our knowledge this is not a Warn Bumper.
After making some templates out of cardboard we needed some steel. After calling in for reinforcements our buddy Bill and Andy picked up the steel and brought it over. We commenced to make sparks to cut out our brackets. We need to kick in for some better metal cutting equipment in the shop as we ate time with a die grinder, angle grinder and even a hacksaw. Andy and I had to secure the plate while Larry sliced.
After another run for cutoff wheels, Andy brought back his killer GMC burb. Specs are 6.2 oil burner with a Banks turbo, 6" all spring lift, 14bff/D44 8lug. The killer part is the exo cage. All DOM and built in sections that bolt on if damaged can be replaced one part at a time. Very trick.
After making the main brackets, we went ahead and ran some diagonal braces to the corners. This added some needed structure to the flat brackets. It's beefy. I think it came out sweet.
I can stand on the corner and it has zero deflection. Now to mount the Xd9000i into the bumper and wire it up.
