So now that im running 40s , hydro assist and a front locker, what spare parts should i bring with me? I have a spare ujoint and fluids
That’s an inner axle seal, not an easy or quick job.
Park that wheel up hill like @Justin V mentioned.
Ok so next question, if its an inner axle seal is it possible it was damaged when they worked on my arb?
Or do these just go out?
The only other weirdness was for some reason the hub was locked so ive been driving it for a while locked, not sure if thats hard on those or not...
I would at least take a look at it, but if you are going that far you might as well put new seals in. Couldn't the front R&P cause it to leak? When was the last time you had the cover off?
The cover was last off when a shop fixed my arb a couple weeks ago.
I talked to the shop he said its possible his guys buggered it up when they were working on the arb. He is going to fix it on Tuesday, either at his cost or "cheap".
Im really weird about leaks. I fix them asap. Even small leaks.
Well and to be honest i didnt get an itemized receipt so maybe he did them and didnt say anything but then damaged it putting the axle in??? I really have no clue...right on
It's kind of odd that the seals weren't replaced when the carrier was out. It's on of those things that only takes an extra 15 minutes while it's apart rather than several hours later later.
Nah, part it outWell and to be honest i didnt get an itemized receipt so maybe he did them and didnt say anything but then damaged it putting the axle in??? I really have no clue...
Its a full on axle shop thats what they do so i imagine they would know to just do those. But eh either way its being fixed so yay!!
