My 72 Jimmy is down in Larkspur, I will check it out this Sunday.
Front legs on both the 70 and 72 are the exact same. I have seen a few other 72's with only two rear legs so they are out there just rare I guess.How do they compare for the front legs / mounts?
I don’t think Blazers ever came with only two rear legs ( my 72 has 4) and usually if the seat is from a different application the tubular front legs and brackets to hold it to the floor are substantially different. Armrests sometimes look odd and can be a giveaway too.
-G
Yeah, in 73 and up there are only 2 legs but the seat is different and the front mounting is also different, it's square on the sides instead of rounded like a first gen.My '74, which uses what I swear is the same seat, has just the two legs each front and rear, and then the seatbelts bolt in the middle two rear positions, if that makes sense.
-- A
I believe the highlander was only for Chevy but not sure if GMC had something similar or not.Any idea if there was a Highlander type option for the GMC Jimmys?
Keep in mind that 72 still had rear seats with all four legs, I think Chevy was transitioning to using only 2 legs latter in the 72 model year, probably why the highlanders are only two as that package was a mid year thing.Interesting. I've long suspected that my '72 was really a '71 because of a few minor differences, but I've never really bothered to find out. My rear seat not matching what you are finding adds to the suspicion.
That would make sense then. Mine is a CST, but maybe also an early one. I didn't even know about the highlander package.Keep in mind that 72 still had rear seats with all four legs, I think Chevy was transitioning to using only 2 legs latter in the 72 model year, probably why the highlanders are only two as that package was a mid year thing.
Ash, where does your rear view mirror mount? IIRC, 69-71, was on the windshield frame. 72 was on the actual windshield.
Mine is a 70 and the frame has the mark but doesn't seem to have ever been used just a glues on windshield mount so maybe not all of them?Ash, where does your rear view mirror mount? IIRC, 69-71, was on the windshield frame. 72 was on the actual windshield.
