Plugs are a bit smelly of raw fuel. Did a comp test all four are @170psi. I'm not confident in this coil Sub harness especially when the looming completely crumbled off when removing it. Ordered a sub harness from PSI ans a Bluetooth scanner so I can finally see what's goin on.
Counter bored the 7 pin mounts
edit : ..... with more pics you posted your hand looks to be covering the flat 4 on the bottom ? ? thats new never seen that before .
wrong plug buddy . . . . :doah: you should have got the round 7 AND the flat 4 all in 1 unit = no more jender bender plug from hell to do flat 4 in round 7 . :saweet:
flat 4 on left side of plug with its own cap . and pre-counter bored screw holes .
edited my post already . never seen one flat 4 under on bottom . :dunno:
also led post in garage has been updated . problem solved with lights .
Yea i just saw that. Kick ass! I never seen one on the bottom either that's why I got it when I was at Napa. It's a Hopkins
if i was a betting man your rear bumper started life as a med to hd truck frame rail by the looks of it . does the bumper have a slight twist from 1 end to the other ? i have made a few out of c-60 or f700 rail chunks my dad saved years ago from when he use to build firetrucks at the local factory when it was open .
I'd imagine it is a piece of truck frame. Didn't notice a twist though. It's welded on so I'm makin lemonade with it right now. Eventually I'll make a tube bumper I suppose
