B
Bent77
Guest
But I’ve not seen an orange 8.1LDon’t encourage him.
Yeah, it's gonna be orange. Like a big cast iron pumpkin. For any other reason that it's not normal.So I bug out for a year, and the plan changes to a big block and a manual? Great change!
Are you going to paint the 8.1 orange?
Martin
But yeah like anything else the project changes as you go. I just want to go without flogging the engine like a rented mule every time I pull up a hill or grade. The engine change forces the transmission change obviously. Nobody I know has ever married an 8.1 to a 700r4 like I have so it was either 4L80e time or nv4500 time. The 4500 fits the same spot without driveshaft alterations, so it's kind of a no brainier.
I don't think I have to convince anybody around here about a big block and manual trans! MAW right?Good to hear about the orange!
Yeah, I went back to where I last read (I actually reread quite a bit), and caught up, so I see all your reasoning. Makes perfect sense to me.
Even if it didn’t, you would never have to try to convince me that a big block and a manual transmission were good choices.
Martin
A friend with a '73 truck that it would be perfect for?What are you doing with the 5.3L? Asking for a friend...
Maybe.....A friend with a '73 truck that it would be perfect for?
Cool.It will go up for sale when I'm ready to pull it for the swap. I've got a customer that expressed interest in it, but that was provided it came out fairly soon. Since that's not going to happen right away I'm not sure if he'll wait.
I'll post up here before I list it elsewhere.
That was a driving reason for the change. I never saw an iPad overheat (it actually said that on screen) and shut off before.That's going to be so much nicer to get your pad out of the direct sunlight and heat this year
Anxious to see the new lower bench installed!
We put spacers on buses and medium duty trucks all the time just not on steer axles. Hell, most truck equipment upfitters add spacers during their upfit to correct leans on a daily basis.
My truck leans left too until packed for a trip and it evenly squats
Would removing a leaf on the pass side front and adding a shim to drivers side rear sound crazy?![]()
