New milestone reached. Thanks to
@Capt Ron ’s used 8.1 emporium the Crawlabago has a new used fat block.
My plan was to get a reman but the cost was just too high for me to pull off right now and be able to actually drive it this year.
CaptRon has been sitting on this engine since he picked it up from Wade before he made the move out of Colorado. The history on the engine is a little fuzzy between Ron and I but the jist is it came from a Schwans medium duty truck and is pretty low mileage. Bonus is Schwans units run on natural gas so it’s should be very clean inside. The outside is spotless for sure. Still clean factory black gm paint.
It’s going to get all the seals replaced, top to bottom and front to back.
Proof of the medium duty origin. The oil pan is giant and has already been modified to remove the front section of the pan for clearance. I don’t think it will fit as the stock truck pan is really close to the ORD engine crossmember. A quick comparison measurement from a stock truck pan from the back of the pan to the front part of the sump was roughly 10 inches. In the modified medium duty pan it’s closer to 13 inches. Thats no bueno.
My buddy Bill made the trek up to Denver to fetch the engine and deliver it down to to Larry.
With the engine secured, motivation has jumped up some. I don’t have much I can do from up here with the truck at Larry’s. But I do have a little 8274 Warn winch I’ve been sitting on for well over a year and parts to upgrade it too.
I’ve picked up a control pack from the newest version of the 8274 that uses a allbright solid state relay over the original solenoids. I got a controller to match and 150 feet of synthetic rope from Warn too.
First up a quick cleanup of the dirty winch.
The winch wasn’t too bad actually. So it is going to get a a quick wheel job.
I tried to push the control pack closer to the body of the winch but the slots for the hose clamps on the pack put it right on the inboard motor studs. So I had to put it where the outboard clamp went outside of the outer motor stud. This motor is still the original and not the newer unit. I imagine the new motor being longer would allow the pack to fit right. It will get the newer motor later but this will work fine for now. As it sits the winch itself is super smooth in all the functions I can do without powering it up. Free spool knob pulls in and out easy and free of any binding. With the free spool on the drum rotates super easy and smooth. Even with the free spool off the drum spins the gear train smoothly (opposite of the brake) and the brake holds like it should. It’s ready for install on the engineered vintage bumper that’s been stashed forever.
