And 241's are easier to run a sye... 208's are mostly hack and tap or swap a dodge back half on unless im mistaken.
yeah I'm not sure if anyone makes a 208 SYE, I've only seen the dodge stuff used.
Screw the SYE
Save for Doubler. Most 205s are factory SYE, the way it should be
Man i can only imagine how much a doubler will put me back lol.
first things first i'll focus on the damaged parts so its trail worthy then i'll start dreaming of a doubler.
Its moved back 1.5" but i think shortening the shaft another 1/4 so 1/2" total should helpWell cheapest route is get the shaft fixed so it won't leak or bottom out any more. May need to shorten it or move the axle back with some offset plates.
Zero leaks.Is it leaking after the fix in Moab?
If it’s not, then let’s just shorten the output a little more. You didn’t have any more issues with it on Saturday right?
Yeah I have done a couple of those dodge Chevy combo tcases.So 89 is the only year 241 with a mechanical speedo.
You could get all crazy with the 208. Find a Dodge fixed yoke 208. Take it all apart and then mix dodge and chevy parts. There is some wierdness when doing it but I don't remember what.
Yes most dodge 208s were fixed yoke.
Fix what needs fixed. Wheel. You dont need to spend any money.
PB wheels pretty good in current form.
Your 700 and 208 is pretty close to a th350 or 400 with a 203/205 doubler.
By the way I had a th350 with a 203/205 doubler.Zero leaks.
I do want to swap it out for one with a plug vs one thats welded. Id rather risk hitting a plug vs a solid metal plate.
