y5mgisi
1 ton status
Very nice! Can't wait to see this thing sitting on its own legs! Curious to see how those Springs work too! Do you already have fancy rear shocks?
Been contemplating a rear setup that can keep up with the front. Unfortunately the springs that I have (deavers) for another vehicle are too short and do not provide enough rate to hold the truck up. Also very travel limited 8.5 inches. So I contacted Deaver about a custom setup for my rig similar to this Solo Motorsports bypass setup for a bronco. They are able to install 12 inch bypasses under the bed and have it capable of 16-17 inches of travel. Deaver stated they could make me a spring that would bolt into the front hangar and have the rear longer to accommodate the longer travel requirements. I should be ordering these this week if I like what I hear.
The cost of linking the rear with new components reaches 1600 quickly, hence the reason I decided against it. I did not want to put the bypasses into the cab to click and clack away behind the baby.
I'm jealous.
This is for Adam...
